kershaw revolver 700
RE: kershaw revolver 700
The 700 size Kershaw motors have 29mm spacing for mounting. Standard spacing is 25mm. These motors are relatively inexpensive for the power you get. The standard 700 is only 19 bucks..........the H.O. version $35. It is possible to modify your plate to fit it.......dont know if you will have enough room around it, and it needs big voltage to produce. Youd be better off going 540 brushless.
