New Slash 4x4 PE?
New Slash 4x4 PE?
I just picked up a PE and was wondering if there is anything I should be looking for? I'm planning on going through it and checking all the nuts/bolts and lock-tighting everything I can, but just wondering if there is anything alse I should be looking for?? Thanks...........
RE: New Slash 4x4 PE?
ORIGINAL: t9dragon
Buy some spare rear axles........... or replace the rear hubs with the stock plastic ones. Alot of people have had issues with the rear axles breaking, due to the aluminum hubs not having any give.
I failed to mention, I had a rtr 4x4 slash that I just sold to my younger brother. I went through 4 different sets of stub shafts, 3 with the plastic hub carriers and 1 with alum set. Thats interesting. Hopefully they figure something out soon on thise things.....
ORIGINAL: jjkRC
ORIGINAL: t9dragon
I haven't had any problems with the rear axles on my RTR 4wd Slash.
ORIGINAL: t9dragon
ORIGINAL: jjkRC
ORIGINAL: t9dragon
The Stock plastic hub carriers solved my bent axle issues . Iwould switch the aluminum out unless you have some spare axles handy . That is if you are planning on getting big air and landing badly .
The bolts on the bottom of thecaster blocks are worth checking , all the bolts and screws are worth a once over .
Highly reccomend the tape mod on the drive shaft to keep the debris out and also putting a couple 3 mm scews in the differential drain holes on the bottom of the truck to keep the sand / dirt out of your gears . A little lexan or folded overtapeto cover the area for adjusting theslipper clutch is wise . That area is a magnet for little pebbles that makea terrible noise and willlathe your slipper nut . Personally , I am gonna get an overtray from JConcpets because I run in alot of looseandwet dirt .The inside of my truck had about an inch of mud coveringeverything today .
