VXL Problem
LA
VXL Problem
I drive a traxxas slash 2wd with a velineon sysyem in it. It is geared 16/86 and I run a 3s 4000mah lipo. About a week ago I had a high speed run in with a metal pole and broke the right rear a-arm. Since then every time i accelerate from a full stop the motor cuts out if I pin the throttle. It does this till about 15-20mph and after that it accelerates fine. It also sounds like it is cutting out any time it gets to full speed if that makes sense. The motor and esc are also getting much hotter than before the crash. Any idea what the problem is? I'm stumped. Battery is staying cool btw
