School me on what to do!
HeyAll,
I picked up a HPI Blitz at my work today, it came with a Tenergy 7.4v 4000mAh High Discharge Li-Polymer Battery. It also came with a Hyperion EOS 0606i (#HP-EOS0606I-C) Charger, but i can't understand what i am supposed to do with it. It said something about using an automotive battery or another power supply (which i think i can get from work) to charge the battery. I didn't have a manual, and the one i found online looked like greek to me. So im hoping someone can help me figure out how to charge this truck up.
thanks guys
thanks guys
RE: School me on what to do!
yea, i glanced at the charger, and didn't take into account it didn't have a wall plug in portion. trying to show my son this truck, and i feel bad i can't even figure out how to charge it
My Feedback: (325)
Turn car off, then transmitter. Remove battery and charge in a safe place. I'd get some help for the first time. Someone to look over your shoulder.
AZ
to charge using a car battery, all you do is clip the alligator clips to the pos and negative terminal on the battery, but make sure the car isn't running.
ORIGINAL: msilage
yea, but do i take the battery out? car on? car off? im used to the wall charges for rc cars
You can make your own lab power supply with a computer power supply quite easily with basic knowledge of electronics and a soldering iron (things you should have for this hobby, if you dont already)
Here is the article i used to create my own.
[link=http://www.instructables.com/id/ATX%3E-Lab-Bench-Power-Supply-Conversion/]http://www.instructables.com/id/ATX%3E-Lab-Bench-Power-Supply-Conversion/[/link]
My Feedback: (8)
Is this your charger? http://www.amainhobbies.com/product_...rger-6S-6A-50W
If so, you don't need a car battery or external power supply. It's an AC/DC charger. You just plug it into the wall and it will work. You can use it with a 12V battery if you want, like if you're at a track and don't have access to power, but you don't have to.
It doesn't appear to come with charging leads (kinda bizare for a $100+ charger), so you'll have to get them separately. Something like this multi-cable will cover pretty much any battery you come across: http://www.amazon.com/Tarantula-Eigh.../dp/B003JDA05K
WV
ORIGINAL: guver
thats the charger it came with, but it also came with another circuit board similar to the one in pictures, that the battery plugs into.
oh i don't take it as being rude at all, like i said, i need to be schooled on this stuff.
i downloaded a pdf of the manual last night, but i guess i gotta find someone local to talk to, cause i am clueless to this stuff
My Feedback: (8)
Weird, it's the same model number, but it's definitely DC only. It's probably a B6 clone, but I don't want to give you instructions for one in case the firmware is slightly different. Your local hobby shop is definitely your best bet here. Bring your truck, batteries and charger and they can help you out. You need compatible charging leads anyway, and they should have them.
AZ
dead link, but i did this also, very easy to do, and works great
ORIGINAL: gelbschnee
My Feedback: (325)
ORIGINAL: msilage
My Feedback: (325)
There's plenty of simpler chargers on the market. I would like whoever sold you this combo to help you with it since it probably was all used together.
My Feedback: (13)
OR
Take it to your local hobby shop (a non-chain one preferably) and have them help you. They might not know the exact details on your charger, but they should be able to figure it out quite quickly. I know I can master a new charger within minutes (or seconds) after scrolling through the menu, same with a computerized transmitter. Then, the next time you want to buy an R/C car purchase from them so they'll still be around next year to help you out further.
-Frank
-Frank
ok so i went to a hobby shop, the guy walked me through what to do, but how do i know when it is done charging? when i hooked it up it was at like 5.456v, right now its about 7.610v and still climbing. not sure when it is supposed to stop
WV
Your lipo is 7.4 volts which is a 2s lipo or in other words it is a 2 cell lipo. The nominal voltage for a 2 cell lipo is 7.4 volts and they should peak at 8.4 volts or 4.2 volts per cell. Never go higher than 4.2 volts per cell as this could damage your batteries and it can be dangerous. On the flip side, never go below 3 volts per cell as this will also damage the battery permanently.
If you battery charger is set properly it should automatically balance the cells and stop charging when the cells reach around 4.2 volts each. Mine tends to go a bit higher and lingers around 4.2 for a good while before it peaks and stops charging. You want to keep each lipo cell balanced at the same voltage. This is important to prevent damaging a cell.
What ESC (electronic speed control) and motor does your blitz have? I'm not familiar with the Blitz's RTR (ready to run) ESC (electronic speed control). If your running lipo batteries your ESC needs an LVC (low voltage cutoff) to prevent the lipos from going below 3 volts per cell. You may or may not need to turn it on manually according to the ESC's instructions. If your ESC doesn't have an LVC then you should probably get an external LVC or LVA (low voltage alarm). The alarm would warn you when to stop running before you over discharge your lipo.
You also need to be charging in a safe place and preferably using a lipo sack to charge the lipo in. Some people also use an ammo case to store and charge their lipos. If at any time during charging, discharging your lipo starts to swell/puff you need to stop what your doing and put the lipo in a safe place away from anything flammable. Swelling is a sign that something is wrong and you should seek help from the hobby shop as it may be time to dispose of the lipo properly. If it does catch fire do not use water to extinguish the flames. A fire extinguisher may work but I'm not sure which type would be best. Smothering it with sand or dirt may be a better option.
I hope this helps a little. If you can post what ESC and motor combo your running it may help others determine if you lipo has a built in LVC.
My Feedback: (325)
The battery is already discharged too low. Is it too late to get a refund? Each cell should be above 3.7 volts resting. You should stop charging and get some help. Or at the least measure each cell's voltage.
ORIGINAL: msilage
WV
ORIGINAL: guver
ORIGINAL: msilage
well i charged it last night, took an hour, ran for about 15-20 mins or so before the battery died. what is the normal run time for one of these cars?
