Stampede
Does anyone know what the factory gearing or what to go to on the older Stampedes,and how many cells can be ran on the speed control.I just got this truck and it seems to be geared high it does not have much low end to it.It has a brand new Peak raven sv2 on it if that helps with the gearing suggestion
RE: Stampede
on the XL-1 I guess you are talking about
[quote] SPECS: Cells: 4-7 Weight: 3.4 oz Amps Continuous: 75 Amps Peak: 100 Dimensions including heatsinks: Voltage Drop: 0.019 2.4" long x 1.5" wide x 1.4" high [quote/] |
RE: Stampede
Stock gearing on the XL1 'Pede is 18/84. On the XL5, it's 19/86
RE: Stampede
Is the motor that is on it a good one for this truck(Peak raven sv2)
RE: Stampede
ORIGINAL: gasfreak Is the motor that is on it a good one for this truck(Peak raven sv2) |
