SC10 360 degree view!
If you haven't seen already
[link=http://www.teamassociated.com]Team Associated[/link] cant tell if its 4wd but im pretty sure its electric. looks similar to slash. aluminum shocks? hard to tell. |
RE: SC10 360 degree view!
i like the mud flaps
i hope its 4wd and electric
pretty sure its electric. did see a muffler or engine head cooling vent in the body. actualy it looks like 2wd. makes sense, so compete with the slash
looks 4wd. I think I see a belt. look in the hub and you can see somthing that looks like one...4wd?:D
are you saying its belt drive? [X(]. that would be awesome. maybe i should hold back on trying to get a micro desert truck. i hope this isnt too expensive like the new Traxxas GoPro camera. anyone heard of that? [link=http://www.traxxas.com]Traxxas[/link] its under the news
waterproof 5 megapaixel mini video camera. amain has it for $250 though...[:@] thats alot of money. but im getting off topic. how about put one of those on the SC10? |
It is 2wd, and based off the T4 chassis. It will be a RTR as you can clearly see the RTR shocks. Also looks like the length are in between a T4/B4 as far as the front arms. Nothing exciting here. Bascially what Losi did with the Desert Truck, but at elast they put some thought into it. ie. 2.4ghz radio, LCD lights, made a new transmission for it.
how do you know 2wd?
look there are no dogbones in the front.
Looks way better than the slash, it will probably school it.
ORIGINAL: carlbellybutton10 how do you know 2wd? |
put your mouse one the middle of the V in "View" and it looks like there is something in the arms
It is 2wd. What you are seeing is the steering toe links. It is just a t4/b4 with a different body and maybe arms. Just like the slash dealio.
Unfortunately losi dropped the ball on the desert truck, IF they were trying to make it a short course truck. Which obviously they were not, so why try to compare them.
GO AE. |
it does look 2wd though
It is definitely 2wd and based off the t4, i dont know how long those mudflaps will last though. Lets not forget about the slash though, if it werent for traxxas, we wouldnt have the sc8, and now the sc10. AE should have to pay royalties. LOL
1 Attachment(s)
Here are some more pictures and info.
Based on a lengthened version of the 6-time ROAR National Championship-winning RC10T4, the engineers behind the doors in Area-51 made the SC10 both all show and all go! The result is the SC10 kit, an authentic scale racing experience. The SC10 comes ready to assemble with a clear short course race-truck body, KMC™ style wheels, aggressive tread multi-terrain tires, all which have been designed to look just like the full-size race trucks that run in short course off-road series around the country. The world of high-performance 1:10 scale electric R/C has never before seen this level of scale accuracy! It’s easy to see that the SC10 is another champion by design! #7027 SC10 1:10 Scale Electric 2WD Short Course Race Truck Kit UPC: 84695 07027 Availability: March 2009 SC10 Kit Features: • Based on a lengthened version of the 6-time National Champion RC10T4 platform • Realistic short course racing truck .040” polycarbonate body • Chassis side nerf bars • Trick KMC™ style wheels and aggressive tread multi-terrain scale tires with re-enforced sidewalls • Realistic bumpers front and rear for maximum durability • Rubber AE logo mud flaps • 2.6:1 ratio gearbox equipped with sealed gear differential • Two spur gears included: 75 tooth for brushless stock and 87 tooth for brushed and modified motors • Efficient dual-sided, externally adjustable slipper clutch • Molded composite low-CG chassis • Hinged battery hold-down strap fits up to 8-cell battery pack • Set-screw secured antenna tube • Durable front and rear body mounts • 14 rubber-sealed ball bearings • Rugged steel turnbuckles for quick and easy suspension adjustments • Fully adjustable suspension geometry • Angled bellcrank “coplanar” steering with integral servo saver • Vertical ball end roll-center adjustments front and rear • Blue aluminum shock bodies • Steel dogbone rear axles • Many Factory Team and Reedy option parts already available! SC10 Specifications: Scale: 1:10 Power : Electric Length: 550mm Width: 293mm Track: 245mm Weight: 2080g Wheelbase: 327mm Internal Gear Ratio: 2.6:1 Drive: 2WD Say thank you! :) j/k |
It is a kit!!!! I was wrong but tis is MUCH better than RTR!
Nice to see that it's a kit, at least AE hasn't abandoned the more hardcore users yet. Excellent looking body too, just like a smaller version of the SC8 shell.
Sweet! Bout time we get to see some pics of this thing.
Know how you can tell its 2wd? The motor guard hiding under that huge rear bumper. Any ideas what the price tag is gonna look like? |
I guess I can take my extra T4 and turn it into a SC10............................
You would have thought AE could have released a "NEW" chassis design instead of reusing the T4. I do like the gear-diff in the tranny better then a ball-diff. |
it looks like a decent truck maybe my next kit need to get away from the traxxas and tamiyas:D
it looks too much like a buggy with big bumpers, big wheels and a scale looking body... it doesn't really seems special. ill see what kinda reviews get out and see what the price is before i decide on it or a losi micro dt.
ORIGINAL: Chris_RC It is a kit!!!! I was wrong but tis is MUCH better than RTR! But no worries, they did that to keep the price down. I'll run the dogbones until they snap, if ever then I'll buy cvds. It looks similar to the desert truck, having the gear diff instead of the ball diff, but people rather have a gear diff anyhow right? |
its under $200 it uses the RTR parts because there cheaper, and its a KIT!!!!!!!:D:D:D:D:D:D
http://www.horizonhobby.com/Products...ProdID=ASC7027 |
