Nicd battery with 3 wires???
I recently bought a cheap toy grade rc car online to bring back the good old days. I have had toy grade rcs in the past and had 3, 9.6v nicd batteries for them. The new car that i bought does run on a 9.6v nicd battery but it is different. Instead of 2 wires for power (red and black) it has 3 (red, black and blue) This makes my old batteries useless. The new connector also seems to be opposite to my old batteries, where the battery is the female end instead of the male end on my old batteries. I was wondering if i could take an old connector and splice it into the car ignoring the blue wire, letting me use my old batteries again.. Im a noob with rc and i just want to drive my rc car for a long time without having to charge it for 4hrs after the 20 min battery runs out. Also i opened up the car, and the red and blue wires run to the circuit board, and the black wire runs to the power switch. Ithought the blue wire would just run the lights so i cut it but it ended up running the reverse, so i put it back together.Please respond.
http://www.ultimaterc.com/forums/i/pbBg.png); margin: 8px 0px 5px; padding-bottom: 5px; background-position: 0% 0%; background-repeat: no-repeat no-repeat; ">
IL
RE: Nicd battery with 3 wires???
ORIGINAL: spazzy222
I recently bought a cheap toy grade rc car online to bring back the good old days. I have had toy grade rcs in the past and had 3, 9.6v nicd batteries for them. The new car that i bought does run on a 9.6v nicd battery but it is different. Instead of 2 wires for power (red and black) it has 3 (red, black and blue) This makes my old batteries useless. The new connector also seems to be opposite to my old batteries, where the battery is the female end instead of the male end on my old batteries. I was wondering if i could take an old connector and splice it into the car ignoring the blue wire, letting me use my old batteries again.. Im a noob with rc and i just want to drive my rc car for a long time without having to charge it for 4hrs after the 20 min battery runs out. Also i opened up the car, and the red and blue wires run to the circuit board, and the black wire runs to the power switch. I thought the blue wire would just run the lights so i cut it but it ended up running the reverse, so i put it back together. Please respond.
http://www.ultimaterc.com/forums/i/pbBg.png); margin: 8px 0px 5px; padding-bottom: 5px; background-position: 0% 0%; background-repeat: no-repeat no-repeat; ''>
You're the best!! I didnt have a digital multimeter or whetever so i just spliced the blue and the red together and used the old 2 port connector and it works perfectly. I now can use my old batteries and they work with no troubles. I tried for a whole day to get another battery with 3 wires, but couldnt, but thanks to your post i actually converted the car back to the 2 wire system. Thanks a bunch.
Same problem but when my blue is not connected nothing works .With the blue and red connected I have throttle but no steering, at a loss atm, old battery is past testing condition (frayed wires ) I have pics of the car in my gallery
