Esc go poof
Esc go poof
Alrigh i almost had a fire in my lap yesterday and i have no idea why.
What i used;
Wp-1040-brushed esc,
Smc 7.4v 7200mah 60c 120b lipo battery,
Futaba T2PH 900mh tx/rx,
Colbalt 2 modified motor
What i did;
i plug in everything, i checked that everything was connected right because earlier that day i changed all endsnto traxxas so i made sure all wires lead to where they were suppose to. I turned it on and eased on the throttle.
End result;
Motor sparked like it should. Then a sizzling nosie followed by e loud pops and then the smoke poured out so thick andfast. I couldnt see anything anywhere. I reached for the batteru and couldnt find it the smoke was so thick and i was sitting right next to the back door whick i had fully opened. Finally i found the bagger and ripped it off and threw the esc out the door and checked quickly for signs of damage to the battery and it looks ok but its a hard case.
Questions;
What went wrong? Should the battery be ok? I have another wp-1040-brushed can i use it with the battery again as ive done 100 times before?
What i used;
What i did;
End result;
Questions;
Moderator
Looks like you maybe didn't have a jumper set correctly? Maybe a jumper jumping two separate pins? Battery should be okay, but measure the voltage with a voltmeter first to make sure nothing screwed up.
Tou cant really see them but both the pins were set closest to the wires on lipo and forward/reverse they always are i have o other batteries than lipos so i never move the pins. Plus i had used that battery/esc combo eaier that day testing a different motor but before soldering but i know the wires were bang on.
Moderator
Thats pssible. I thought i was quick enough doing it but i addmit i not the greatest at soldering and burn my finger holing a wire because it wouldnt go right. But the positive wire came right out after the esc blew up. But i had used that batteery/esc combo before testing out a different motor the only real differencw being i was using an adapter to go from the red banana plugs to a traxxas plug.
Now i have another wp-1040 that i soldered how can i check if its ok?
NOTE: the batter was/is the right way i checked and have been using it on my brushless since the esc problem.
Possible. But how would you explain my use of it after i soldered it. It was soldered and used a couple days ago while the the battery was soldered that day and used since?
Ok guys please im begging for some advice... i just lost my second wp-1040 and could have been more... this time a new esc presoldered ddifferent controller different motor. And tbis time i tested the esc no motor and it was perfectly fine. I connect a motor and turn on the power and sizzle but this time i was sort of expecting it from when i tested with no motor and built in a kill swictch which i hit the second i heard the sizzle. What the heck is going on pleeease help mr.
