RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
Old 07-21-2009, 09:58 PM
  #301
Kirker
Default RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
ORIGINAL: alexchen86
I just got the Flux last weekend and I am loving it! I am seeing if anyone has pictures on what they did to cut the back plate so rocks do not get lodged between the belt and they pulleys.
thanks,
Scroll back in this thread!
Old 07-21-2009, 10:05 PM
  #302
hpidriver94
hpidriver94's Avatar
alexchen86 look at page 2
Old 07-26-2009, 06:40 AM
  #303
FireFrenzy
Hey i might be getting one of these puppies to complement my e10 and i was wondering if there are any "must have" upgrades, if i do that diff mod thing will i need anything else? For example the e10 needed (almost by law) a full set of bearings.
I read something about som egears stripping near the rear belt, would it be a good idea to drop in those HPI aluminium belt gears? as for the spur gears stripping is there anything you can do about that which is cost efficient? I´ll prolly toss in a 9 turn EZrun system for power while using either 5100 mAh team orion rocketpacks or possibly upgrading to lipo´s in the future...
Ooh and one last question, i see conflicting reports on the wheel base, some sites list it as 190mm while others list it as 200... Also the HPI site lists it´s "deep dish" rims as an advantage are those offset wheels to get it to 200 from 190 or something??? (my e10 is 190 so not having to keep 2 body sizes on hand would be awesome...)
Old 07-26-2009, 06:17 PM
  #304
hpidriver94
it has a 200mm wheelbase and i have never stripped the pulleys
Old 07-26-2009, 07:56 PM
  #305
ct03si
i just picked up a sprint 2 flux yesterday, it is my first on-road car.
so far it is nice it handles waaaay different than my 2 traxxas slashes(obviously) and it is stupid fast.
but i got a 6 cell 5000nimh pack for it andit didnt even run 20 minutes!!!!! i run 7 cell 4200packs in my brushless slash and i get almost doublethat time on it!
could itbe because the pack is brand new and only got charged 1 time? or should i just forget it andmodthe batterybox to fit my 7 cells!!
also i noticed that it gets really hot since it is so low to the ground, the air cant get up underneith it to cool the motor. im considering cutting out the front grille to help get some air in there
and 1 last question, does anyone know what offsets the wheels are on the flux with the new mustang gtr body?
Old 07-27-2009, 10:15 AM
  #306
zxsonnyxz
I belive its 3mm offset in front and 6mm on the rear ones.
I'm not a 100% sure tough...
Old 07-27-2009, 11:09 AM
  #307
FireFrenzy
that sounds like with 0 offset wheels it´d be 190....
Old 07-27-2009, 11:56 AM
  #308
ct03si
cool thanks guys, also last night after running it a bit and seeing how hot it gets, i cut out the front grille to help flow some air through the chassis.
Old 07-27-2009, 08:03 PM
  #309
Kirker
I had read somewhere that the mounting posts were adjustable so that you could use either 190mm or 200mm bodies. Has anybody else heard that?
Old 07-27-2009, 10:05 PM
  #310
Car-Tune
What mounting post? where the body sits on? you dont need em. You can just place a 190-200mm body on these cars. I have a 190 on my RS4-3 with no problems and swap with sons Sprint Flux.
Old 07-28-2009, 04:06 AM
  #311
Mufasa_719
The 190 and 200 is the with not how long. 190 electro and 200 nitro but eather could be used.
Old 07-28-2009, 05:42 PM
  #312
intimidator_md
intimidator_md's Avatar
Recently got this Sport 2 off ebay. Came with graphite upper deck, graphite front and rear suspension towers, sway bars and 2 speed transmission and stiff springs. Handles like it's on rails and I put a Speed Gems 15 in it and it flies pretty well. Here is a pic with my new mini cam mounted on the roof. I need to make some on-road vids to post soon. As soon as the BMX track dries up I will mount it in my Slash and make some hardcore bashing videos.
BTW, anyone put 9mm offset wheels on theirs??? I got a sweet 1980 Camaro body from Mcallister racing that is 9" wide and I was wondering how close the track would be to the body width with 9mm wheels on it.
ID:	1245380   Click image for larger version
ID:	1245381   Click image for larger version
ID:	1245382   Click image for larger version
Old 07-28-2009, 08:31 PM
  #313
Kirker
Ok, so you can then use either 190 or 200 bodies on it. Not for the reason I said but you still can. Soooo, it sounds like you can usually use either size on a 1:10 you just might use different offsets to make it "look" right? Correct?
Old 07-28-2009, 08:40 PM
  #314
zanga254
zanga254's Avatar
two speed transmission? Is it from another company or does it look custom?
Old 07-28-2009, 10:02 PM
  #315
hpidriver94
its from hpi but its for a different model and im not entirely sure if its adaptable but it might be
Old 07-29-2009, 12:17 AM
  #316
Mufasa_719
ORIGINAL: Kirker
Ok, so you can then use either 190 or 200 bodies on it. Not for the reason I said but you still can. Soooo, it sounds like you can usually use either size on a 1:10 you just might use different offsets to make it ''look'' right? Correct?
You are correct sir. Just use off-set wheels.
Old 07-29-2009, 12:18 AM
  #317
Mufasa_719
So me and a buddy of mine decited to get into 1/10 on-road. Low and behold we went with the Sprint-2 drift rollers. Should be here friday.
Old 07-29-2009, 04:25 AM
  #318
FireFrenzy
where do you get those rollers? are they the chassis listed as "assembled" on tower or something? i´d like to know incase my second hand deal for cheap doesnt come through and since i am going BL on this one anyways i dont really need a full built with electrics and the like...
Old 07-29-2009, 05:42 AM
  #319
joeyhatch11
Just wanted to give you guys a heads-up. I had a Sprint 2 Sport that I was using some lipos in and being that I sold the Sprint I have no use for the lipos. I have them listed here if you want to check them out. One is a 4000mah and the other is 5000mah, both 7.4v 15C. Only asking $45 shipped and will even come with a small lipo charger for those of you that dont already have lipos. It'll be a cheap and easy way to get into it. Run times are about 20 minutes with the 4000mah and 25 with the 5000mah. Thats a lot of running on only two batteries. As for the two-speed question, I've seen that post before in here, back when I had mine, and I think they were saying it wasn't possible because of the chassis lay out. I think your only option to have electric two-speed, you'd have to convert a Hpi RS4 nitro.
Old 07-29-2009, 07:18 AM
  #320
Willystylz
Willystylz's Avatar
ORIGINAL: FireFrenzy
where do you get those rollers? are they the chassis listed as ''assembled'' on tower or something? i´d like to know incase my second hand deal for cheap doesnt come through and since i am going BL on this one anyways i dont really need a full built with electrics and the like...
http://www3.towerhobbies.com/cgi-bin...?&I=LXSGF6&P=7
Old 07-29-2009, 08:21 AM
  #321
FireFrenzy
Thanks man!
Old 07-29-2009, 09:12 AM
  #322
Willystylz
Willystylz's Avatar
if you're not going to use it for drifting just make sure you get a normal set of tires.
Old 07-30-2009, 04:28 AM
  #323
Mufasa_719
Sry fire I diddent get back to ya in time.
@Willy- I am going to give drifting a try but chances are I am going to set it up for club racing. Its just that only the drifters come as rollers. I would be a wast to get the rtr just to rip everything out just as soon as I open the box. Ya know
Old 07-30-2009, 07:02 AM
  #324
Willystylz
Willystylz's Avatar
oh i hear ya, i did the same...
Old 07-31-2009, 07:00 AM
  #325
Mufasa_719
LOL,
Now I am finding motor fitment to be kinda tricky. My VXL just wont fit in there. O well andther $150+ trip to the LHS. Good thing the wife loves me LOL
