Where Can I Buy 5mm shaft 30T Pinion Gear For TA05????????
As i said in the title ...also I'm in Japan and will need to order a couple online cause I couldn't find any here....
This is for a high speed TA05 (over 70miles)
I tried drilling a regular one to this size but it hasn't worked very well []
anyone know of someone who stocks these??
Thanks!!!
Thanks!!!
RE: Where Can I Buy 5mm shaft 30T Pinion Gear For TA05????????
Wrong link bro??? Thanks for tryin though
If you running a Tamiya spur the HPI site probably won't help anyway as they are metric and most other makes are standard. Have you tried Tamiyas site? I don't know how large they have available but worth a check. Also try RCMart.
dude you're in japan, home of tamiya and you can't find a tamiya part???????????????????????????????????????????
1 Post
ORIGINAL: theheadhunter
In the wheel section of HPI>>>>????
ORIGINAL: SIRCC
Apart from that dude Japan strives to keep everything within the norm
I showed them this motor in Super Rajikon (biggest RC store and their jaws dropped) they never use or order anything unusual ...they also play it within the norm on parts for sale reasons ...
So if you want anything that they have never heard of here good luck finding it
Japan is not as modern (in many ways as people might think lol) apart from the Electronics Industry
ORIGINAL: redfisher1974
Sorry wrong link it was suposse to be a link for Novak.com.....Hope i didnt give the novak link to the guy who wanted the hpi rims...lol
In that case my sincere apoligee, can you post a picture of what you got, maybe i can better understand your problem and help you find a solution
1 Post
ORIGINAL: overrev
just buy the standard 30 tooth pinion and drill it out to 5mm.
ORIGINAL: SIRCC
ORIGINAL: overrev
ORIGINAL: Wild YFZ 450
What pitch are these pinions?
the ta05 is 48p...i just heard that I might be out of luck []
