CSM simulator under XP fix?
I noticed recently that the problems I had running CSM v10 under XP (won't respond to the Tx. most of the time) are solved if I DON'T USE THE MOUSE.
If I run XPHELI.BAT & navigate/select just with keyboard it always works OK (so far).
As soon as I move the mouse it stops responding to the Tx.
Hope this helps someone!
Kevin
Kevin
