Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 2 questions about RF6 >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 12-02-2011 | 08:20 AM
Default 2 questions about RF6
#1, Everytime I use full elevator defelction I get roll added into it. I can't complete a clean tight loop as the planes nose always ends up going somewhere else. I've tried and tried to calibrate it out but can't. Anybody else have this problem?
#2. How hard is it to hover? For the life of me I can't get anything to hover, the nose is always wandering around when I go vertical and stop climing. It's either yawing or pitching and I can't keep up with the inputs to keep it straight.
Old 12-11-2011 | 06:56 AM
My Feedback: (325)
Default RE: 2 questions about RF6
1. Mine definately doesn't have this problem. It loops nearly perfect every time even at full elevator. Which plane are you using? I will try it.
2. I'm not sure I could help you here because I am not good enough to hover. I have used the airplane hover trainer and every input works flawless. There is no choice of planes though in the trainer. Whenever I try to hover at a field , the plane acts as expected.
Old 12-11-2011 | 07:11 AM
exeter_acres's Avatar
both of those things happen in the real world......
pull a hard elevator and you are inducing a stall.. you have to counter it with rudder and aileron.....
and #2.. same thing.. watch videos of people hovering... there are always corrections going on.. you have to be ahead of the airframe.....
sounds like the sim is working fine.
Old 12-11-2011 | 05:29 PM
My Feedback: (325)
1. I have experienced this with Giles 202 plane. It is pretty fine on low rate, but when high rate is selected it does exactly as you described.
