FUTABA TX IN AFPD
Hi guys,
Don't know if im in the right place, here goes.Does any body know if a futaba T6EX 2.4 G TX will work work in aerofly pro delux.
could somebody give me answer pls.
Dave.
Dave.
Hi mmiranda 10
My usb plug gets recognized on computer, cant get it to show up in game controllers ive tried every thing plugin, unplugin, renamed
tx as well, rebooted you name it ive tryed it
Just shows up not connected. Just hopeing i may have over looked something.
Dave
Dave
ORIGINAL: pilotpete2
Are you trying to use a generic USB cable? If so, that's your problem. You must have the USB cable (dongle) that comes with the package.
Pete
Pete
Hi Pilotpete
Had to buy new dongle/usb plug fits in back futaba ok the other end usb which came with the dongle package.
Regards Dave.
ORIGINAL: exeter_acres
forgive me as I really know nothing about the T6EX radio... but some of the higher end radios need to be in either trainer mode or in PPM mode to work.
Hi exeter tryied in trainer mode wont work got to fathom out how to put it into ppm mode ill let you know if it works.
Regards Dave.
HI GUYS
PPM mode on, Trainer mode on, still showing not connected in game controllers. rudy used to work cant understand why not know.
Hi guys
Think ive found the problem the new dongle i bought wont work in AFPD, but it works in Refex also
just read some where that flight sim dongles are not inter changeable which means my afpd disc is useless now. If anyone knows of a way round this please let me know.
Many thanks for your input guys.
Regards Dave.
Regards Dave.
GA
That is part of the copy protection of the AF flight sim....
the serial number in the dongle is paired with the serial number in the software.
If you bought the software off of Ebay or something... without the USB cable...then sadly it is worthless....
if you lost your dongle (man that sentence just sounds wrong!
then contact the folks at Ikarus with your serial number and they should be able to help
)then contact the folks at Ikarus with your serial number and they should be able to help
Exeter
you must be clarvoyant you are right i moved house not so long ago i think maybe thats how its gone missing.
I will get in touch with ikarus see if i can get a new dongle.
Regards Dave.
Regards Dave.
