Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Joystick(single stick) or 2 stick controller? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 11-19-2003 | 03:50 AM
Default Joystick(single stick) or 2 stick controller?
Coming from a Pc back-ground, what are the benefits of the 2 stick vs the single stick controller?
Since I'm used to the joystick which one would be better? or is just a matter of preference?
Single stick tx are out there, I found guide on here just by searching for !QUOT!single stick!QUOT!, even though they are not common place.
I wanted to know, if you use a joystick for your computer (such as a flight simulator, r/c or not) or do you use the standard tx to computer conversion device?
Let my know your opinion, thank you.
Mr Boulevard
Old 11-19-2003 | 07:56 AM
Default RE: Joystick(single stick) or 2 stick controller?
I started using Dave Brown RCFS version 4.0 about 10 years ago. I borrowed an adapter from a friend to be able to control it with my Futaba Conquest 4NBF. I liked to brush up on maneuvers before going to the field. One several occasions I had to cut my flying short because the transmitter batteries were marginal. I returned the adapter and constructed my own controller from an old Conquest buddy box and some potentiometers. I much prefer the controller to the adapter.
