G2 Simulator Q's
RE: G2 Simulator Q's
Yes, you certainly can. First, you make a copy of the aircraft that you would like to fly. Then, select that aircraft. When it has finished loading, press "E", to edit the aircraft.
Under "Radio Type", select the "My Own Radio" choice, and click Edit Now. Good luck, Andrew
WA
I'm sorry I wasn't very clear in my question, I meant that I only had the software for G2 and I was wondering if they made some sort of cable to connect my radio to the computer so I could use that. Thanks for the help.
ooo, no, as far as I know, you cannot. From what I've seen, if you try to run it without the controller, it just gives errors. But a couple days ago, I did read something about changing DirectX drivers? Do a search. -Andrew
