RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
RF G2 air craft????
Old 05-16-2002 | 02:44 AM
Default RF G2 air craft????
Is there any where out there that a guy can download more airplanes, and/or helis for RF G2? I have been looking but not having much luck so far.
Old 05-27-2002 | 04:51 PM
Default Try...
...this page:
http://www.realflight.com/swap/index.html
It's the only source I've found so far, hope it helps!
Old 05-27-2002 | 06:20 PM
Hi there.. How do you go about adding these things to RF?
I have loaded all of them.. All 3 Things.. the schemes , aircraft and Fields.. SO how do i make them work in R/F? I have the latest ver of RF g2.. if that helps.
THANKS!
Jeff
Old 05-27-2002 | 06:44 PM
My Feedback: (8)
Cougar. When you say you have them loaded do you mean the scheme (.jpg/.tga) files are in the "color schemes" folder, planes are in the "planes" folder and airports are in the "airports" folder? If so then you're set. Just choose the file like any other when you are in Real Flight. I've got all three add-on discs plus a mess of files I've downloaded. The list of planes,shemes and fields is getting pretty long now.
Old 05-27-2002 | 06:47 PM
Ok I have made 3 folders for them ALL.. Still loading the Schemes tho.. *LOL*.. But now take them and drop them into RF Folders then? and Extract? or what?
THANKS!
Jeff
Old 05-27-2002 | 06:53 PM
Ok I just drop the planes into the folder (RF) folder and I cant see them when I open RF.. DO I have to extract each plane in that folder?
Jeff
Old 05-27-2002 | 07:03 PM
I think I did it! Way kewl!
Thanks!
Jeff
Old 05-27-2002 | 07:05 PM
My Feedback: (8)
I'm assuming you are talking about .zip files. I like to keep a separate archive of the files so I can restore them in case I modify them too much within R.F. So....... I would "extract" them to their own archive folder then copy them into their respective folder in R.F. A plane file will have the file extension .pln, a color scheme file will have the extension .jpg or .tga and an airport will have the extension .airport.
If you still have trouble e-mail me at:
[email protected]
Old 05-30-2002 | 09:46 PM
You might also check out The Unofficial Swap Page http://zeus.rcwizard.com/fubar_hill/G2.htm
Lots of files, some are on both sites some are unique to either one.
I do have a little explanation of where the files go on the main page also.
Old 05-30-2002 | 11:08 PM
WOW , thank you very much.. And you load the same way?
