Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 How do I do it?????? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 12-20-2003 | 01:46 AM
Default How do I do it??????
Hey Fellows
I'm going crazy here, We have a G2 flight sim setup at our local Hobbyshop and when I'm there I'm always flying this Edge that someone made, well the problem is when I come home to fly mine, I try and try and can not for the life of me get the same kind of plane setup, Iv even type everything on a piece of paper and then put it in and its still not the same, Is there away I can download what he's done and then install it in my PC, if so how do i do this, I'm not very good in the PC world so please explain it as easy as you can...
Thanks a lot
Randy
Old 12-20-2003 | 04:51 AM
My Feedback: (50)
Default RE: How do I do it??????
You will need to go to the hobby shop that has the sim, assuming you have permission to do this. Simply locate the Real Flight program folder. Usually you will find this on the C:/ drive in the programs folder. Once you locate the RFG2 program folder, open it and look for the planes folder. This is where all of the planes that are on that system will be. Copy the plane file that you want to a floppy or cd. Take it home and open it up and place the file in your plane folder in your Real Flight program folder. Then open Real Flight as if you were going to play. Go to Select aircraft and scroll to find your new entry.
You can also find some pretty decent plane files on the Real Flight website.
Hope that helps.
