RF Without The USB
No, it can only be bought with the interlink. And even then, you need the interlink to play the game. You get an error message if the controller isn't plugged in. -Andrew
MA
Scott,
I have the "old" serial port version of RF with a controller, and they also used to sell a serial port version that came with an interface cable to your Tx. You may want to check ebay peridically as there are almost always versions of RF on auction. They don't sell what you are looking for new anymore, but you may find a deal on a used one.
Carl
Carl
cfossa, I think he is just looking for a way to bypass a controller all together because he says that he doesn't want to have to pay for a controller; he wants to just use his tx.
But even with the serial port controller, don't you need a Realflight controller? I think, Mudsurfer, that with RF you're going to have to buy an Interlink/serial port controller just to play the game. -Andrew
Ok, here's the real scoop.
Prior to Spring 2002, RealFlight G2 was sold with either parallel port interface or a game port controller. The software was protected from copying using one of the strong protection schemes. Once this protection was broken, some indiscrete people started copying RealFlight G2 CD-s and using the sim with 3rd-party controllers or even regular joysticks.
The response of KnifeEdge, the developer of this sim, was to add a special USB controller and rely on it as on a copy-protection-device: the sim will not start without this device attached to the PC. They went to great length to make this new Interlink controller hard to imitate, so that it's technically difficult to make another USB device, which will present itself as an Interlink controller. Fortunately, Interlink controller is quite a decent piece of hardware, it's worth every penny and AFAIK it comes with G2-Interlink upgrade disk.
The difference between pre-Interlink G2 and G2 Interlink is rather small. All G2 upgrades can be applied to pre-Interlink G2 to bring it up to date. All Add-Ons work with pre-Interlink G2 too.
