Realflight
Is there any kind of adapter that you can get that you can hook your regular radio (like 9chp) directly to your usb port and use realflight g2?
I would like to run realflight at my mom's and home without having to buy two controllers or bring them back and forth.
Thanx
Thanx
No. You have to run your TX thru the interlink controller that G2 supplies. I dont even think you can buy a seperate controller if you wanted to. Im pretty sure you have to buy a whole new G2 with disc and all. Its Realflights way of controlling piracy. Its a shame really as even if you were to damage your controller you cant buy a replacement.
This guy is just selling an interface with his G2, so there must be a way of doing it.
[link=http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=3170322223&category=34 056]RealFlight G2[/link]
dont quote me but I think you use to beable to buy G2 with either an interface or the interlink controller. When they upgraded to the USB version they removed the option of the interface and went soley with the interlink. You cant buy G2 new with an interface only option. When you install the USB version it requires the interlink controller serial number to be entered on setup. There may be away around it with a cracked version of G2 but that would be illegal!!!
AP, BARBADOS
NZ-KIWI is correct. That is the old version of G2. You used to specify which you wanted, controller or interface. It connected through your parallel, instead the new system connects through USB (much better in my eyes).
