Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Need help with heli's on G2 >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 01-23-2004 | 11:28 PM
Default Need help with heli's on G2
Hello,
I just installed Realflight G2 and I'm trying to fly the Impala trainer. The problem i have is she drifts to the pilots left. I tryed right trim, but it still drifts... Is there a way to set it up or to "0" the settings in it? Or am i just doing something wrong... It seams like the tail has a mind of it's own, no matter where i set the trim it still wants to turn one way or the other... Help
Thanks in advance,
Tim
Old 01-24-2004 | 09:20 AM
a65l's Avatar
My Feedback: (17)
Default RE: Need help with heli's on G2
I forget which switch numbers they are, but the switch on the upper left hand side of the transmitter controls the engine govenor and the tail rotor gyro. If you don't have the gyro engaged the tail is a handfull. It's normal for a heli to drift a little bit when flying (I have only simulator experience flying helis) and it will want to drift left when pulling power to take off. Check out the virtual flight instructor's bit on taking off...
HTH
Andy
