Yak55sp For Aerofly Pro
ON, CANADA
A new Yak55sp model for AFP that includes 4 differnt paint schemes. It is based on the Composit ARF 3.3 meter Yak.
[link=http://members.shaw.ca/ghaydt/Yak55sp1.zip]Download Here[/link]
Ben Dean: Model-Tweeking
Geoff Haydt: AFP implimentation
RE: Yak55sp For Aerofly Pro
Just flew it. If the real one flies like that, I want one! Only thing is, (in my humble opinion) the ailerons need more throw. Other than that it's awesome! Jordan
My Feedback: (41)
Wow that thing is a 3D maniac. Flat spins both upright and inverted are great. Hovering and torque rolls are just a little harder than the CAP 232. I really like this plane. The elevator and rudder throws are huge. The knife edge is almost zero coupling of any type. I can do knife edge loops very tight. I find myself doing very low flatspins by just playing with the sticks, very cool. then right at the deck I end up in a hover.
It needs more aileron throws? How so? What can't it do with the throws as is?
It's set up with loads of power that's for sure.
Joe
Joe
My Feedback: (20)
NC
ORIGINAL: BansheePilot
[link=http://members.shaw.ca/ghaydt/Yak55sp.zip]Download Here[/link]
I am setting up a new computer so it will be a few days before i get to check it out, but i thank you and will let you know how i like it.
I installed it (named the folder Yak55sp), but it doesn't show up in the list of aircraft.
Is this intended for expansion pack users only?
Ken
Ken
My Feedback: (20)
NC
ORIGINAL: kgough
Ken
Ken
Directory of C:\Program Files\IPACS\AeroFly Professional\aircraft\Yak55sp
01/25/2004 10:56 AM <DIR> .
01/25/2004 10:56 AM <DIR> ..
01/24/2004 07:41 PM 22,802 Black.jpg
01/24/2004 07:41 PM 21,841 Blue.jpg
01/24/2004 07:43 PM 44,166 Default.jpg
01/24/2004 07:41 PM 12,472 eng.jpg
01/24/2004 07:41 PM 25,631 Orange.jpg
01/25/2004 10:56 AM <DIR> Skins
01/24/2004 07:35 PM 30,819 Stand.jpg
12/08/2003 11:26 PM 12,344 Thumb.bmp
01/25/2004 11:18 AM 1,356 Yak 55sp READ ME.txt
01/24/2004 07:42 PM 107,528 Yak55sp.jpg
12/28/2003 08:06 PM 1,242,577 Yak55sp.obj
12/28/2003 08:06 PM 26,596 Yak55sp.tmd
12/28/2003 08:06 PM 3,102 Yak55sp.tmg
12/08/2003 12:47 AM 3,145,784 YakBits.bmp
12/08/2003 12:36 AM 786,488 Yakengin.bmp
12/07/2003 11:50 PM 3,145,784 YakFuse.bmp
12/07/2003 11:50 PM 3,145,784 YakWings.bmp
GA
Thanks, BansheePilot. The Yak flies GREAT!!!!! How do you change the color schemes. The aircraft menu in AFP only shows the red, white & blue one, however, the other schemes are in the same folder. Thanks!
My Feedback: (20)
NC
Hey Ken
Well it's obvious you have it in the right folder? You might want to try and un-zip it once more and reinstall it back to the same folder after you have removed it.
Sorry for the lack of help.
Wow that's a fun one! Is it just me ar are tailstides very easy with it? I just thought it needed a bit more aileron throw to liven it up a tad.
ON, CANADA
To change the paint job go into the AFP/Yak55sp/Skins/ Open up any of those 4 folders (Black, Blue, Orange or Default skin) the 2 files YakFuse.bmp and Yakwing.bmp are the skins. Copy both of these files and paste into the original AFP/Yak55sp/ directory. It should replace the 2 skins already contained.
Geoff Haydt
Geoff Haydt
My Feedback: (21)
NY
Banshee ... love the plane. It's awsome. Tail slides are most impressive.
Hey are you interested in doing the OMP GS 540 Edge?
Please let me know.
[email protected]
THANKS!
Please let me know.
[email protected]
THANKS!
My Feedback: (314)
i guess im a computer dumb dumb.....i downloaded the file....if you use windows explorer....you can see that is listed in the folder with my other aircraft....when i pull up afp...to choose an aircraft....its not there...any advice?
My Feedback: (20)
NC
ORIGINAL: edgreenlee
Did you un-zip the file first?
My Feedback: (20)
NC
Hello Ed
When I down load a plane I send it to my Document, then a folder just for
AFP downloads that I have set up ( New Folder ).
Then right click the file and then click on Extract all. Now the file should
be un-ziped. You can now send the file to AFP, aircraft.
Now Just open two windows, one with the new un-ziped file, and the orther
window have AFP expanded.
Now you can just drag and drop the file right into AFP aircraft folder.
This for Windows XP but should work with other OS.
HTH
HTH
My Feedback: (19)
Thanks Ben and Geoff
I flew the snot out of the Yak last night and I love it. You did a fantastic job on the graphics and flight envelope.
Although I must say since I can do rolling harriers with it it must not be very realistic
I found that it needed quite a few changes to fly REALLY realistically in harriers and elevators and other manuvers.I found that its nose came up in harriers way too high and early.
After all, our goal is realism, rarther than having a plane that makes you look like you fly awesome, leaving you dissappointed with yours skills when you get to the flying field.
However, its still a great plane, well done to whoever designed it.
If anyone is interested in having a go with my modified Yak, send me a pm and i will email it to you.
My Feedback: (21)
NY
ORIGINAL: Luke 3D returns
My Feedback: (21)
NY
I have been told by an owner of the Yak 55 50% with DA 200 that it flies almost identical. He said it was the most realistic plane he has ever had or seen.
I have also seen him fly at Joe Nall, and it was the most stable plane I had ever seen.
You do realize this is designed as a 50% aircraft and not a .46.
I would have to say your assumption is inaccurate until you have flown the plane.
