AFP - Best Sim ever --nothing comes close
#76
AB, CANADA
Here is a Heli pilots views on AFP
After some tweeking of the Raptor , Fury, and Mille 60
More HP , more Cyclic, more tail speed for all heli models .
The Raptor launched very much like my R 50 " same climb rate "
The Raptor Rolls very much like my R 50 " same roll rate " my rolls really SUCK just like my real Raptor "
The Loops and flips are almost identical
So I am very Happy with AFP
Fred..
Fred..
#78
Can the graphics be turned up from the stuff shown in the movies?? Not nearly as nice as my Reflex and looks like it can do all of the stuff covered in this sim... Never tried it mind you, just judging from their movies... My Reflex almost looks and flies like the real thing so not sure anything can ever be better...
#79
My Feedback: (21)
NY
ORIGINAL: ahhfoo
#80
AB, CANADA
Fred, what are your AFP and Tx settings for the Raptor ? Thx
Tx is a standard heli set up
Nornal Pitch 0, 25, 50, 75 100
Normal throttle 0, 40,50,60,100
Idle 1 Pitch 0, 25, 50, 75 , 100
Idle 1 throttle 100, 60, 45, 60, 100 " V "
The Aerofly Raptor " changed settings "
Weight 2600 g
Pitch -10 + 10
Cyclic pitch 8 deg
Piro speed 720 " Nice and fast piros "
Engine 180 Kw " More HP "
Blades 100 grams
I have less ATV elevator in AFP 75 %
with 100 % elev the raptor is very pitchy.
I am still messing with the settings
The rest of the settings are factory
Fred..
#81
My AFP uses on onboard graphics card (16 mb) so your external should be fine.
though mine does run at 7 FPS!
My specs
P3 550
128 RAM
the rest is unimportant
Compatibility question - I have a laptop with an Intel 852GME Integrated Graphics Controller with 32 MB external DDR ****M. I don't think that it's a graphics card, per se, but would it work with AFP?
My specs
P3 550
128 RAM
#82
Moderator
My Feedback: (58)
ORIGINAL: 440GTX
rajul Here are my settings
Weight 2600 g
Pitch -10 + 10
Cyclic pitch 8 deg
Blades 100 grams
Fred..
Weight 2600 g
Pitch -10 + 10
Cyclic pitch 8 deg
Blades 100 grams
Fred..
#83
AB, CANADA
Fred, the stock power is 0.9kW, pls confirm if your setting is 1.08 kw rather than 180kw ? Thx
Should be 1.08
Fred..
