Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Sim To Help Me With Snap Spins? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 06-08-2004 | 08:46 PM
P-40LUVR's Avatar
Default Sim To Help Me With Snap Spins?
I crashed a CAP 232 a couple of weeks ago when I tried to hang it on the prop, it snapped went nose down spiraling into the dirt!
With that said...I bought Aerofly Pro,should get it soon,will this help me in stall recoverys or snap rolls..like the CAP 232 is famous for?
I really don't want to crash another plane because I can't get it out of a stall.
Thanks.......
Old 06-09-2004 | 06:53 AM
Spacey's Avatar
Default RE: Sim To Help Me With Snap Spins?
AFP will help. Not too much because caps ARE just famous for this Which is of course not really all that a bad thing because they also do the most beautiful snaps and spins. AFP will help with everything! But it might not really cure that problem forever. Take the cap on AFP and wring out. Force it into plenty of stall situations and it could keep you from dumbthumbing the plane yes. But it won't cure the plane.
Old 06-09-2004 | 07:28 AM
My Feedback: (21)
Most snap stalls to crash happen because you try to pull elevator to recover when all you are really doing is pulling it even harder into the spin.
The best way to recover from a snap is to relieve elevator pressure instead of adding back elevator pressure. The rudder is the most effective input and the most effective tool in a spin which is in the opposite direction of the spin, but only after you have relieved the elevator. Letting go of the controls is not going to always help either, however it's better then pulling back on the elevator. The whole idea is to stop the spin then recover.
Many of times was I on the field and seen someone bury a plane because they spun into the ground. I walk up and ask them how they tried to recover and they said "i was pulling on the elevator as hard as I could and it would not come out".
The BEST plane to practice this is the new Corsair for AFP. This is the first plane that I ever flown both RC and Sim that you actually have to work it out of a true stall to spin. It's GREAT to practice for any airplane. I personally think the best flying plane I ever had my hands on the field or on the sim.
