Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 EVO 12 and Reflex XTR >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 06-27-2004 | 12:18 PM
My Feedback: (17)
Default EVO 12 and Reflex XTR
Can anyone tell me how to fabricate a plug that will let me use my EVO 12 with the new Reflex XTR flight sim?
I want to order the Reflex XTR sim, but I can’t find it available with a plug that will fit the EVO.
Has anyone been able to do this?
Thanks, Villious
Old 02-07-2005 | 12:45 AM
Default RE: EVO 12 and Reflex XTR
Unfortunately I do not believe that you can manufacture a plug that will work with the Reflex sim. They have a one gate proprietary on-board chip attached on the usb end of the cable and it cannot be duplicated. If you have a chip reader you might be able to find out the hand shaking code is embedded in the on board chip. However, in order to do that you need to get your hands on an existing usb signal converter and then analyze the signal. Suppose that you might get a chip to try to figure out its code....usually they have safety one way voltage gates and as soon as you try to pass their threshold of voltage as you try to invade in their proprietary code they snap and become useless. I have spend quite some time trying to do what you ask and I had no success. If you find a way to do it please let me know because I have a copy of the reflex software sitting on my desk that is otherwise useless.
