Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Can anyone assist with G2 Autorotation? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 08-21-2004 | 07:45 AM
flyoz's Avatar
My Feedback: (7)
Default Can anyone assist with G2 Autorotation?
Hi Guys I have tried the real flight boards but no response so far--pretty usual.
I am having a bit of difficulty using / assigning T hold for Autorotation.
I get the Instruction video ok and have also set up the Controller under Airplane then sw Radio etc.
But- throttle hold just doesnt seem to work on any switch.
Throttle cut does ( the tail blades stop immed and rotor follow soon after)as do other functions .
When assign THold (to any sw) nothing seems to happen but maybe im missing somethingbeing a beginner ?.
A step by step on how to set up in G2 would be a big big help if anyone can sapre the time
Old 08-21-2004 | 09:26 AM
Default RE: Can anyone assist with G2 Autorotation?
Uninstall the entire G2 program and disconnect the USB Tx. Restart your computer.Then install the program again , after that install the USB controller. Restart again. Choose calibrate controller automatically.Leave switch assignments as they are, throttle hold will be automatically assigned to the right switch on top of the transmitter (is it Mode 2?). Have you droped the Tx or something? Upgrade the G2 program on-line using the Realflight control panel. Before uninstalling note down the product id and registration numbers.
Also, open the on screen view of the virtual radio and see how the lettering on the virtual transmitter turn red on and off when turning switches on and off. What you are refering to as "throttle cut" is actually "throttle hold"
Old 08-22-2004 | 04:38 AM
flyoz's Avatar
My Feedback: (7)
KingX thanks a bunch mate. good brain fodder Ill try it.
PS boy you guys have a pretty venue fo the Olympics the Horse riding hurdle field with the boats etc was bl..dy spectacular[8D] not to mention those beautiful mountains in the background of the Skull races.[X(]
Well Done to Greece
Old 08-22-2004 | 02:39 PM
Thanks a lot FlyOz for your encouraging words! Feel free to ask any question about G2 at any time.
