Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 G3 installation problem >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 12-21-2004 | 10:05 AM
Default G3 installation problem
Hello
Can't install G3.
When I try to install G3 at the end of the installation process I Get the following error message:
KEError 16510: Failed while creating shortcut.
Old 12-21-2004 | 11:08 AM
Default RE: G3 installation problem
Are you logged in to the pc as a local administrator? If not, then that will create problems.
Old 12-21-2004 | 11:21 AM
I try to install directx 9c, new windows installer and G3 run.
Thank You
Old 12-21-2004 | 11:49 AM
When I try to reinstall G3 all repeat again
Old 12-21-2004 | 02:10 PM
I think Sailor is right, you must not have administrator priveledges on your machine. What OS are you using?
Old 12-21-2004 | 04:37 PM
I found the problem. My OS - Windows XP Russian version SP 1 and program installation G3 does not understand localization.
You have to set up the Multilanguage pack for Windows XP English version SP2 then G3 installation will work.
But the helicopter upgrade will not work.
.ru
