Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 AFP Deluxe questions >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 12-24-2004 | 08:10 AM
Matt Merciez's Avatar
My Feedback: (34)
Default AFP Deluxe questions
I have some AFP Deluxe questions that hopefully someone can answer.
Would you please provide some details regarding the controller that will be offered with the sim this spring, in particular:
[ul][*] Will the controller support multiple rates? [*] Does the software support programming with the controller such as custom mixes?
[/ul]
Can a player import/create photorealistic scenes for AFPD? If you can import a scene, can you program in objects? Can you program sufface characteristics (grass/pavement)?
What are the editing features for planes in AFPD? Can you easily paint new schemes? Can you easily modify the models?
Thanks in advance.
Old 12-24-2004 | 08:39 AM
My Feedback: (21)
Default RE: AFP Deluxe questions
The controller has 2 sticks, 2 switches and 1 knob. It is not a computer radio, it's analog. So you can't program featuers only assign the switches and knob.
However AFP will do whatever your computer radio will do. Mixes, rates etc.
You can edit just about any parameter on AFP Deluxe. Much more then you could do even on your own plane. Dozens of parameters. I'll get some screenshots up soon.
Painting is really simple too, just use any paint editor.
Build airplanes and scenery can also be done, but it takes some know how. There are workshops on the web however.
http://www.rcuniverse.com/forum/How_...2455541/tm.htm
http://www.rcuniverse.com/forum/HOW_...2455534/tm.htm
