Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Posting G3 re-paints here >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 01-19-2005 | 01:00 AM
  #51
Razmo's Avatar
Default RE: Posting G3 re-paints here
What you should do is, instead of moving the exhaust smoke component, add your own smoke components. First move the Engine's "Smoke" component towards the back to match where the black smoke is in the pic. Change the smoke color to black. Then right-click on the "Fuselage" component in the tree and select "Add Smoke Component" twice. You will then have two more smoke components for which you can change the color/location. Be sure to also hook those new smoke components up to the smoke servo by clicking on them in the tree, then changing the "Smoke Servo" property from "No Servo" to "Smoke Servo."
Worked beutifully! Thanks
Raz
Old 11-24-2005 | 11:29 PM
  #52
decastave's Avatar
Hey I just had a question about how do you paint the stock aircraft? I look under my G3 folder and subfolders, but I can't find were I can take the origanal color scheme and modify it. The only one i can change is the color schemes I've already downloaded. Any help would be appriciated
Old 11-28-2005 | 12:43 PM
  #53
When you have an aircraft that you want to paint selected in the game, go to the menu, "aircraft->save color scheme as" and type in a name. You will see a message telling you where the new color scheme is saved.
Old 11-29-2005 | 12:24 PM
  #54
Could I please have the new paint as well? [email protected] thanks the link for rick dalton will not work for me.
Old 11-29-2005 | 12:39 PM
  #55
Rick Delten's Avatar
You can get my paint schemes [link=http://www.rfmodels.com/PaintSchemes/]HERE[/link] now msb931223. They are being generously hosted by "nemo uk".
Old 11-29-2005 | 08:51 PM
  #56
Thank you very much!
