RealFlight G3 Basics - Newbies apply here
#151
RE: RealFlight G3 Basics - Newbies apply here
ORIGINAL: rightflyer
I just got G3 and was wondering if there are any airports available for indoor flying? I don't want to wait for the Add-on if I don't have to.
#153
NC
Hi im new to this g3 sim just would like to know how to keep what im flying in sight, im not real good at turning and when they get so far out i can not see what im doing. 'IN TIME IT WILL FLY"
#155
OR
Yes, the zoom functions will help you. Press Z to cycle through the zoom modes, +/- keys to zoom. Also know that the problem of flying away from yourself is something you will have to overcome if you intend to fly a real model, so while it may be frustrating at first, it's great practice.
#157
Hi All - Well I've been running G2 for about 4 years now. My brother picked up G3, and so I thought I'd upgrade so we can share airports. New question. I switched it over to Full Screen by using the Alt - Enter, and it worked fine. I press the Alt key and the menu pops up towards the top of the screen where it should. It is in a much smaller font/format however. Still works fine though. The problem is when I use the ALT - F4 key, instead of coming out of Full Screen and returning to the regular default, it just shuts the program down as if I hit Exit. Any ideas? I am currently down loading the latest update, so maybe it will take care of itself, but I just thought I'd ask.
GPutt33
GPutt33
#159
Yep - I hadn't any more then asked the question, then went back to G3, and tried that, and it went right back[X(] Yep, I'm a G3 Newbie
TN
I did the latest update version of G3 which allows you to download airplanes that you already have on it, however, I would like the basics on how to do this. I downloaded a zip file and extracted it, put it in the program file G3 under the planes folder, however, the plane is not showing up when I go to the select aircraft option on G3.
I also would like to know how to download paint colorschemes. I step by step help would be good.
#161
TN
I am having trouble downloading paint schemes to my latest version of G3. I have the airplane already in my select aircraft.
Here's what happens. I downloaded the paint scheme in a zip file. I extracted the zip file. There are 3 files in there.
1. .plnG3 extension
2. .dds extension
3. colorscheme extension
I went to the import option of G3 and none of the files came up as they were not .g3x.
I then changed then renamed the extension of all three files to .g3x.
When I tried to import each one, it said "import failed"
What do I do?
1. .plnG3 extension
2. .dds extension
What do I do?
#163
OR
Where can I get G2?
#164
NC
Thanks for the help seems I just needed to play around with the G3 some and works great helis are wild just as hard to fly on g3 as in the field just cheaper LOL I love slaming them from real high and see how far the parts go back up.
#168
CA
Help please Dell 4550, P4 2Gig , 768mb ram Geforce4 mx420 64mb, Will G3 work well. Thinking about a FX5200 256mb card agp (do i have a agp slot) Thanks for any help. Rick
#171
ok just got g3 and loaded it on a viao it wont run it said that i have no 3d graphics can i get a download online to fix it (afpd wont run on it ) what should i do
#173
for those asking about their cpu specs and if g3 can be played on it, you should check out the demo. i would think if you were able to play on the demo the full version should be ok
#175
CA
Bought G3 on ebay, (sold as used only cause box was opened) well it was used and registered now I can't register it. Is there anyway I can re-register it.???
