RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Reflex and 7CHF?
Old 01-24-2005 | 09:32 PM
My Feedback: (19)
Default Reflex and 7CHF?
I bought a copy of Reflex XTR, and bought a Futaba square type connector from Xtreme RC since the software came with JR interface...
Anyhow...
I got the sim started, but the radio wouldn't power up from the PC's power, I have to keep the Tx power switch On... and Channel 3 (throttle) is not coming up with a Signal in the Center Calibration, however my Collective Pitch does work when I move my Throttle/Collective stick up and down on the Tx....
So, I read up on a few threads about checking the interface cable. I popped mine open and found only two wires, a Black on Pin 2, and a Green on Pin 3, and Pins 4 and 5 have a bridge of solder across them.
help?!?!?
Old 01-24-2005 | 10:27 PM
jimmyd56's Avatar
Default RE: Reflex and 7CHF?
I had to reverse wires on my cable to get my 7CHP to work. Your colors are different but if you switch the 2 colors and remove the bridge it should work.
Good luck
Jim
Old 01-24-2005 | 11:49 PM
My Feedback: (19)
i switched the two wires and didn't remove the bridge and it seems to work...
I'm getting Channel 3 throttle working now..
the shop i bought the cable from told me that the bridged contacts anable the "tranier" mode in the 7c
Did you remove the bridge though?
Old 01-25-2005 | 08:16 AM
jimmyd56's Avatar
I removed the bridge and I remove the crystal when using sim. Glad you got it working
Jim
