Any Simulator Screenshots(pics)!!!
#176
Banned
Awesome flying pimp!! You are soo much better than the last time I seen you fly.
ORIGINAL: rcpimpin101
How about some video in this forum? Here is me on G3 w\ the yak, I would of done a freestyle but the FRAPS trial version only records 30 seconds at a time[
http://southsidefunnies.com/userfile...in101/RFG3.wmv
]http://southsidefunnies.com/userfile...in101/RFG3.wmv
#180
at the wakeboarding forum there were some guys who posted a 3d video from AFPD and the guys there thought it was awsome. And at first they called it real
#187
Paraphrased from a previous post by
"Matt3D you need to take your sizes down otherwise this thread will be useless for dial up users.
That image is 343k. Bring it down in size and compression please."
Over 600kb of images.
#190
Here is the new skin for AFP(D) Extra 330s. It is based on the UK's Xtreme Team! Xtra300.
you can download the plane+skin [link=http://www.angelfire.com/pro2/fred-aa/]here[/link]
#194
ORIGINAL: STLPilot
Now that's nice. Do you mind if I host it on AFP's site so it doesn't get buried in the thread? That one's a keeper!
Love it.
Love it.
Dave: not sure about the smoke thing in AFPD, I got smoke in AFP.
#198
hmm.. that's strange..
Try:
1. download the VTOC extra 330s from aeroflypro.com if you don't have this plane
2. load the VTOC extra in AFPD, see if you can turn the smoke on this plane.
3. If this plane has no smoke, then we have to end here, I can't figure out what's wrong
If the VTOC extra has smoke
1. go to plane editor to create a copy of this plane
2. name the new copied plane extra_test
3. exit AFPD
4. copy the extra330s1.bmp, extra330s2.bmp, extra330s3.bmp, extra330s4.bmp, and thumb.bmp from the extra330et folder to extra_test folder
5. launch AFPD, load the extra_test plane
6. see if you can turn the smoke on this plane.
7. If there is smoke => problem solved OR
8. If there is still NO SMOKE! then exit AFPD, try use your graphic software, scale down extra330s4.bmp to 512x512
9. Reload AFPD and extra_test plane
10. If you had tried all the above, and/or your main.mfc in the config folder already set the maximum texture size to 1024 and you still have no smoke on the XtremeTeam extra, then
11. I don't really know what's wrong...
Try:
3. exit AFPD
#199
THANKS mm00mm00
Ive just tried the above no joy. All the vtoc extra330s smoke until you change the colour scheme. not to worry m8 its all right as it is. Its realy wierd when you swop around colour schemes, some smoke ok an some dont smoke at all. perhaps one of the techys can solve this mistery ie what file the smoke is in and if we got to add a script or alter the existing script.
THANKS again for your time m8
Regards Dave
Regards Dave
