SmartPropo Software
MS
Does anyone have the most recent version or any version of the freeware software SmartPropo? I have built my FMS adapter cable but cannot get the software as the authors site has been down. If anyone has it please email me.
thks,
[email protected]
thks,
[email protected]
I'm looking for that software also did ever get it? If so could you send it to me please?
[email protected]
[email protected]
Shaul Eiz .. took over the development of Smartpropo. Here is the last version.
[link=http://n.ethz.ch/student/mmoeller/fms/alpha/smartpropoplus.zip]n.ethz.ch/student/mmoeller/fms/alpha/smartpropoplus.zip[/link]
(les than 400k)
The 'README' file:
SmartPropoPlus - Using your Transmitter as a Joystick for FMS
This package contains 5 different files named winmm.dll.
They are located in separate folders under folder "bin"
You have to copy appropriate file into the folder where file FMS.exe resides.
If you are using any PPM transmitter (which is the most common) - copy the file that is
inside "PPM"
If you use a Futaba PCM transmitter - copy the file that is inside "Futaba_PCM"
If you use a JR PCM transmitter - copy the file that is inside "JR_PCM"
If you use a SANWA or Airtronics PCM transmitter - copy the file that is inside
Sanwa_PCM1 or Sanwa_PCM2 according to the modulation type.
If you are not sure, try all 5 files one-by-one until you succeed.
Inside the zip, you will find a PDF: 'SmartPropoPlus' giving very good technical explanations. Please read it.
Sources are included, as with the original smartpropo version.
PS: Shaul Eiz .. is looking for a hosting website that would provide fast response time in case of updates. Please contact me if you are willing to host this zip. Thanks.
Phil.
keywords:simulator joystick dll fms cable connector mike new version last simulateur câble connecteur simu audio micro jack plug futaba jr sanwa airtronics ppm pcm line nouvelle derniere version download free source
(les than 400k)
The 'README' file:
inside "PPM"
Phil.
TN
I will be more than glad to host it email me at [email protected] if you want me to host it and any other stuff.
Thanks a lot to GRR-Mafia for the hosting:
http://smartpropo.mafiadesigns.net/smartpropoplus.zip
Phil.
Phil.
New version 2.0.3 thanks Shaul Eiz..
[link=https://sourceforge.net/projects/smartpropoplus]https://sourceforge.net/projects/smartpropoplus[/link]
Works better with XP SP2.
Phil.
Phil.
Shaul announces a new site for SmartPropo Plus:
http://www.geocities.com/shaul_ei/SmartPropoPlus.html
Phil.
Phil.
And with an audio connection (PPM signal of your transmitter to line or mike input of your PC), you may look at your channels (up to 12 !).
Download RCAudio.exe here:
http://users.skynet.be/phildc
No parameters, no settings, no dll...
Phil.
search keywords: radio signal channel probe scope look view connector buddy box rc model cable simu sim simulator monitor
Phil.
new alpha version of smartpropo (this is v 2.1.0, will later replace 2.0.3 )
[link=http://www.geocities.com/shaul_ei/SmartPropoPlus.html]http://www.geocities.com/shaul_ei/SmartPropoPlus.html[/link]
Commens from Shaul Eiz.. (the author):
Please try and comment.
Highlights:
- Single DLL controlled by a GUI console.
- Manual & Automatic shift selection with improved PPM encoding.
Since this is an Alpha release I'll be happy to learn what you think about it and receive bug reports.
The link is the usual SmartPropoPlus homepage - take the 2.1.0 option and do read the documentations!
Hope you'll like it.
Highlights:
