Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
GS Plane size versus scenery problem >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 09-21-2002 | 02:04 AM
Default GS Plane size versus scenery problem
I have downloaded some planes and some are 40%. the problem is that all big planes are submerged partially in the ground. ie: the wheels are not visible. The bigger the plane the deeper it sits in the ground.
Is there anything to correct this problem, did I misss something ??
Could'nt find a thread on this subject.
Help is appreciated
Old 09-21-2002 | 11:37 AM
Badge's Avatar
My Feedback: (21)
Default Size
All you have to do is go into the aircraft setup and edit its visual scale. Make the plane smaller and it will be fine.Generally we don't mind how it looks on the ground we just want it to be a good size in the air.
Mike Badger
www.Aero3D.net
Old 09-21-2002 | 07:19 PM
try making the u/c legs a little longer in the planes setup?
