Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
USB Interlink installation problem >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 09-28-2002 | 09:26 PM
My Feedback: (19)
Default USB Interlink installation problem
I purchased the USB upgrade and i'm having a problem. It's says the flight box not connected even thou the orange light is flickering.
I went thru the install wizard and no sigar. Please help.
Isaac
Old 09-29-2002 | 08:20 AM
Kanain's Avatar
Isaac,
Check www.knifeedge.com for the forum. I seam to recall some post concerning the USB ILink and specific G2 version numbers. I do not remember that actual version. I am running G2 with Interlink upgrade and version .570 without problem on a XP Corporate Edition O/S. I upgraded to .570 from .550.
Please check your version number in the Control Panel and update to .570 if you have an earlier version.
Also check the control choices to make sure you have selected the Interlink controller and are not still using the original controller setting.
Let me know if you are still having problems and I will gladly to a test install on another of my computers to help you out further.
Old 09-29-2002 | 04:51 PM
My Feedback: (18)
Did you install the upgraded software that came with the interlink controller upgrade? I initally thought it was just another copy of G2, but mine didn't work either until I installed the new software...
Old 09-29-2002 | 08:59 PM
My Feedback: (19)
Yes i have and nothing.
