Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 It's HERE for AFPD, PPS variable pitch! >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 05-24-2005 | 09:07 AM
  #101
Default RE: It's coming for AFPD, new patch, new feature!
Hi!
I'm going to try the "Knuffel" next.
Old 05-24-2005 | 09:14 AM
  #102
My Feedback: (21)
ORIGINAL: rcfun2005
yea ,,, graphics are great !!!
i have never seen a PPS for real...
can real rc planes really do what is in video ??
thanks
They sure can! Ikarus is coming out with new system ... www.ohiomodleplanes.com/pps for Shock Flyers that will fly just like that.
Old 05-24-2005 | 09:17 AM
  #103
Mudsurfer1234's Avatar
greg, can you send me the monsoon you did?
[email protected]
thanks,
scott
Old 05-24-2005 | 09:52 AM
  #104
so what is good PPS electric motor and prog combination ??
new to PPS so looking for standard type motor easy to install ..
thanks
Old 05-24-2005 | 09:54 AM
  #105
"Ikarus is coming out with new system "
see post above...
it may help
Old 05-24-2005 | 10:08 AM
  #106
Scott,
I see what I can do. I'll send a selection!
Greg.
Old 05-24-2005 | 10:30 AM
  #107
My Feedback: (21)
Hey guys Lego just posted this in another forum ... but check this out. He's already working on a true PPS "look feel" for his models!
This thing looks AWESOME. He said it will be ready in a couple days.
Old 05-24-2005 | 10:33 AM
  #108
Well done Lego.
Greg.
Old 05-24-2005 | 10:46 AM
  #109
My Feedback: (21)
And in blue! I would say that the Slow Ride PPS would be the ultimate in foamy flying ... I don't know how it could get any better.
Old 05-24-2005 | 10:49 AM
  #110
Oh that looks soooo good[8D]!!
Greg.
Old 05-24-2005 | 10:55 AM
  #111
Ian.W's Avatar
pllllleeeeaaaaaassssseeeeee Dion make IPACS do this for AFP pllllleeeeaaaaaassssseeeeee
Old 05-24-2005 | 10:58 AM
  #112
My Feedback: (21)
Ian it's not going to happen ... sorry. They don't do it on purpose, they do it because it's just part of their software evolution process. Pretty common in all of the software world.
Just get the update.
Old 05-24-2005 | 11:17 AM
  #113
I wish I could do somthin to help Ian.
Has any one else done a backwards landing!!??
Greg
PS. Scott I sent them hope you have DSL or Cable because the proper verions will come out soon!!
Old 05-24-2005 | 11:51 AM
  #114
Ian.W's Avatar
id get the update apart from they wont take damaged cables apparently guess what!? mines nearly dead ive had to re solder it loads but its on its last legs! ah well, over 200 hours of service, i cant complaini was planning to buy a sim com to replace it soon.....
Old 05-24-2005 | 12:28 PM
  #115
Here's how to take off backwards:
Old 05-24-2005 | 04:20 PM
  #116
Hi folks,
I just uploaded the new PPS-SlowRide.
[link=http://www.kdkuehn.de/sim_afpd_indoor.htm]Download SlowRide-4D[/link]
I set it up a bit more realistic than the original IPACS-Shocky. In reality the PPS does not react that quickly because of the plane's mass. It allways takes you 1-2 seconds from full throtthle ahead to full thottle back.
It's really amazing, what IPACS released now. Just wait for some big TOCs with that PPS-thing... uh, uhhhh
Edit: oh, I forgot to mention, that the skins of both, the normal and the 4D, are compatible. Just copy the green skin over the blue one and vice versa (ensure to have a backup of them).
Have fun!
Dietmar (Lego)
Old 05-24-2005 | 04:29 PM
  #117
I love it in blue.
Thats incredible detail of the PPS. Is possible to make it move like a real one?
Greg.
Old 05-24-2005 | 04:47 PM
  #118
Hi,
don't know. Maybe. But 99% of the time you will not see anything of it. So it might be a big efford for (almost) nothing.
Greets,
Dietmar
Old 05-24-2005 | 04:53 PM
  #119
Good point.
Are you going to do a Monsoon?
And will it really be possible to do somthing like a 40% TOC plane PPS for AFPD ?
Greg.
Old 05-24-2005 | 05:00 PM
  #120
My Feedback: (21)
Lego I sent you an email of the Slow Ride that Geoff made which I used in the video. His seems better flying then your download ... or maybe his is just over tweaked?
Either way give it a try and please provide feedback on it. Just so know which one is more realistic. I know in Germany you've been flying the PPS systems for sometime, but us Americans are behind the times.
If a true PPS is more difficult to fly ... then that's the one I want to fly.
PS - I told you that question about the collective pitch was coming! I'm sure it will be asked a hundred times too!
Old 05-24-2005 | 05:34 PM
  #121
Dion, any idea when the "real" PPS systems will arrive? I ordered the combo system on May 20th and haven't heard anything on
my order.
Old 05-25-2005 | 04:59 AM
  #122
Hi,
usually the pps needs some seconds to change the flight direction completely.
E.g. if you fly horizontally, take the nose down at full throt forward and you pull backwards with the pps, the model will still continue for 1-3 meters before coming to a full stop and beginning flying backwards.
That is simpy because the model's mass.
When transitioning from full backwards to full forward the model reacts emediately because the wings and rudders get the prop-stream and you have at least after 0.5 sec full control again.
Transitioning the other way round you lose control very soon because the prop-stream fades.
When you try to hover upside-down you normally lose control at all but the model seems to be stable for a short moment - maybe because of the propeller's stabilizing effect - don't know...
When the model begins to move backwards you have a slight rudder effect, so you can control the direction a little bit. But that works only a few seconds after changing directions because the rudders must gain some airflow again.
@Dion, I will have a look onto your version of the SlowRide when I am back home tonight.
Btw.: the pps-system many guys here in germany use, is a modified rotor-head of the IKARUS Piccolo-Pro. It is not too much efford to adjust it to a LRK motor. But of course you need a hollow axis for the motor the the pitch-control-stab.
And - yes, I plan to do the Monsoon too... [8D]
Greest,
Dietmar
Old 05-25-2005 | 05:09 AM
  #123
Lego,
Sorry to be a pain but could you do the EDGE-TREME (from slow-flyer.com) 4D PPS?
And I have a Monsoon in real life (in the building process) I was wondering if it is a realistic proposition to do this 4D PPS?
Many thanks.
Greg.
Old 05-27-2005 | 04:10 PM
  #124
8KCABrett's Avatar
Dion, any idea if some control reversal in backwards flight will be modelled? This presents realism issues for tailslides, but now with the variable pitch props it seems like it will be an even more important flight model component.
Old 05-27-2005 | 09:27 PM
  #125
My Feedback: (21)
I don't know and it's a good question, I will find out.
