Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Reflex Interface problem >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 05-13-2005 | 09:35 PM
Default Reflex Interface problem
I just installed the Reflex XTR with a new Dell PC and the software wont recognize the radio. I installed the Reflex USB drivers per the help menu and it shows as working under device manager.
Old 05-13-2005 | 10:12 PM
rcpete347's Avatar
My Feedback: (251)
Default RE: Reflex Interface problem
HI, I have the same problem with Aerofly and my Dell. what you have do do is disconnect the USB keyboard or get a PS2 keyboard.
Rcpete
Old 05-14-2005 | 04:15 PM
Thanks for the tip
Old 05-14-2005 | 07:47 PM
DeepSouth's Avatar
I had the same problem with my system. If you have a JR radio one fix is to solder a 5.6K ohm resistor across the wires at the radio end of the patch cord. This fixed mine and it works great. There is a description of this fix on the Reflex web site in support/transmitters/JR Radio
Old 05-14-2005 | 09:12 PM
I have almost the same problem. Although, mine did work for a while, then slowly it started losing connection a lot. One day, it would not connect at all. NO signal from interface, tried everything obvious i could think of. Had to send it back to MRC (U.S. Distributor) for a new interface. STILL Waiting. Also i have a Futaba round radio.
Old 05-15-2005 | 08:22 AM
Got it working.
