RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
AFPD
Old 10-30-2005 | 10:47 AM
Default AFPD
i am tinking about buying afpd and was wondering how do u guys use ur trans mitters dosnt it drain the battery???? could u plz explain it to me?/?
Old 10-30-2005 | 11:35 AM
Mudsurfer1234's Avatar
Default RE: AFPD
get an adjustable AC adapter from radio shack, set it to 9 volts, cut off the plug and solder on a battery connector, TA DA instant unlmited 9 volts
Old 10-30-2005 | 12:04 PM
My Feedback: (21)
Default RE: AFPD
Do NOT do what Mudsufer just said unless it's not a primary radio and you only want to use it for the sim. It can't be just any 9V converter either, it has to be a certain amount of amps too otherwise it will kill your radio. My suggestion is not to do this at all.
The simulator uses very little battery life because it turns off the RF function when you plug in the buddy cord. I go about 10 days of use on my JR before I need a charge.
Old 10-30-2005 | 08:40 PM
Default RE: AFPD
thanks for the info i went to the store and found out exactly what you said!!!
