RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Newb Questions.
Old 01-29-2006 | 04:29 PM
Default Newb Questions.
1. Which is the best flight sim for learning to fly a gas trainer .40 size?
2. Can you buy a interlink cable seperatly for G3?
3. I was planning on buying a T7cap but I have read to use your own transmitter on some programs you must have at least a 8 channel tranasmitter. is this true?
Any help would be apreciated.
Old 01-29-2006 | 05:31 PM
50%plane's Avatar
Default RE: Newb Questions.
On G3 you would probably be on target flying the PT40. G3 comes with everything you need for hooking up any radio.
On a side note, I would suggest that you buy the 9Cap.
Woops
Old 01-30-2006 | 01:24 PM
You will be somewhat limited with a 7-channel if you want to fly helis. With planes, 7 is plenty.
Old 01-30-2006 | 06:01 PM
ok i held off buying a transmitter to save another 2 weeks to get ye ole cap9. I went ahead and bought the G3 simulator with cable and controller. Can i play any other simulators or games with this set up.? Doesn't really matter but i wouldn't mind trying a couple others. And i may wanna do helis in the future so the cap9 sounds reasonable.
