Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 My Interlink keeps breaking! >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 01-29-2006 | 05:16 PM
3DSAVAGE's Avatar
Default My Interlink keeps breaking!
I have realflight g3 for about a year and the interlink keeps breaking. I have sent it in with the same problem 5 TIMES[:@]!!! The problem is the stick makes a cracking noise whenever it is put over the center. I sent it to realflight and i got it back only for it to break AGAIN[:@][:@][:@]! What is wrong with these controlls?! Are they pieces of junk or something? I'm tired of this happening! What is wrong with these frickin things?!
Old 01-29-2006 | 05:27 PM
Evanator's Avatar
Default RE: My Interlink keeps breaking!
Sometimes when you use it alot the screws unders the knobs loosen............................tighten it [sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif][sm=punching.gif]
Old 02-03-2006 | 08:48 AM
3DSAVAGE's Avatar
i tried that. it didn't do anything. any other ideas
Old 02-03-2006 | 09:01 AM
Evanator's Avatar
It's probably doing that because of wear. I too have had G3 for almost a year but my computer wouldn't install it, so now i've been playing it for about 6 months and nothings happened to mine. It's probably wear or a package error
Old 02-03-2006 | 09:03 AM
Evanator's Avatar
Send it back and get a new controller.[sm=tired.gif]
Old 02-03-2006 | 05:54 PM
3DSAVAGE's Avatar
iVE done THAT FIVE TIMES! I got a new one and had the same problem even FASTER[:@][:@][:@][:@] What is up with these thingz are they junk?!!!!
Old 02-03-2006 | 06:08 PM
Evanator's Avatar
Well............I don't know wat to tell ya'. It's either shipping issues or you need to buy one from a store......... With out that you'r lost[&o]
Old 02-03-2006 | 08:59 PM
E-Mo's Avatar
My Feedback: (12)
i had probs with my Tx
did not want the headaches you are havin
on my thro/ rudder lost the tension
my fix-WOT with a rubber band + helps keep the rudd centered too[:@]
ID:	401406   Click image for larger version
ID:	401407   Click image for larger version
Old 02-03-2006 | 10:58 PM
3DSAVAGE's Avatar
dude that is the exact same problem i have.[:-] Is that just a light rubber band? And guys, why does this keep happening?
Old 02-04-2006 | 12:08 PM
3DSAVAGE's Avatar
Its the right stick though, not the throttle.
Old 02-07-2006 | 12:45 AM
F2G-1's Avatar
My Feedback: (13)
Settle down Francis!! That happend to me, - twice! took it to the hobby shop, manager fixed it in 2 minutes. Slamming the throttle hard is what causes it, jams the inards up a bit. Last time it happened i fixed it myself - open the back up, one of the tiny pins in the yolk (kinda like a u joint) pops out, so now there is no fulcrum conection to pivot on, spring pulls stick to corner, cuz there is no throtle spring. Sounds more complicated than it actually is, you have to stare at it awile to see it. compare the left side to the right to see it.
Good luck!
Ted
Old 02-07-2006 | 05:36 PM
3DSAVAGE's Avatar
that is kinda like what I saw when i had it opened up for me. there's a little circle thing in a little recessed area and the noise was the circle thing popped out. what can i do to fix it.
Old 02-08-2006 | 11:25 AM
F2G-1's Avatar
My Feedback: (13)
You are close, look around, try to find arm connecting to pin. Like a little tiny universal joint in the center of the two yolks, when one of the pins pops out, it doesnt let the yolks center properly. Its hard to see, keep staring at it as you move the gimbal, then look at the other side as you move it. for sure you'll need a small screwdriver to jam it back in. Theres alot going on in there, so its kinda confusing, but onece you fix it once, its not so bad.
Ted
