csm v10 and windows xp help me
i finally got the sim to work but my computer wont pick up the transmitter acting like it,s not there ? something to do with having to find a way to activate parralell port
Hi Ergo: try this link:http://www.rcmodels.org/csm/v10.htm,it has a windows xp patch there hope this helps
The XPHELI or XPAERO batch file does not seem to run after unzipping the files and adding to the registry...
How did you get CSM to work in WindowsXP?
Hello Hoovers,
I would not recommend to buy the CSM 10 simulator because it was designed for archaic systems. I purhcased it but it never worked. Especially the graphic card is a problem. I have a GeForce4 MMX. Neither the Xp, W2000 patch does work nor starting the computer in DOS mode (I hate that, Dos 6.2). I tried run it in compatibility mode - doesn't work neither. Spent 180 EUR and countless hours. Forget about it.
I have recently bought the Reflex simulator and can recommend that. That's what I want.
