RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Clearview...Help.
Old 08-20-2006 | 10:08 PM
Default Clearview...Help.
Hello. Some days ago something weird happened with my Clearview installation: I tried to load the P-51 Mustang and the program closed. Then it resetted to the School field and helicopter. Well, I just tried not to use the P-51, but just now it happened as well with the Katana,. I can't select any of these models because the program simply ends like if I were closing it. Help? Thanks.
Old 08-21-2006 | 10:56 AM
Default RE: Clearview...Help.
There are some parameters in model's params.txt file which if changed to wrong values will make the program to close. Looks like your P-51 and Katana models are now corupted. Delete them from under c:\Program Files\SVKSystems\clearview\models and re-install them again. After that, start ClearView and all should be ok.
Stefan
http://rcflightsim.com
Old 08-21-2006 | 09:30 PM
It solved the problem. Thanks, Stefan!
