rc2joy Interface
Hello,
Anyone out there who have build the rc2joy interface from rcdesign site?
I need help as mine is not working after completing the circuit. No respond when runing joystick test but Windows detects the interface when I plug it into/off the joystick port.
Any help appreciated.
Thanks.
Thanks.
My Feedback: (87)
Hi there
I built the TX/Interface desribed at the location pointed to by the following web site. Works like a charm with RF and DBFS or any program that uses the joystick interface.
I modified it a bunch to elimate a bunch of parts. I have a 10ch TX so don't need the parts around 5+.
The parts are readily available in N.A. at Digikey. Let me know if you need help locating parts.
RSN
http://myweb.absa.co.za/eric.brouwer/interface.htm
RSN
Hi Cloudniner,
Did not see the rc2joy interface on your web site. Mind posting the version you modified?
You also mention you build it and it works. What version of the firmware do you have? I am looking for version 1.0 of the firmware as the one posted has a glitch. Mind sharing if you have version 1.0 of the firmware.
Thanks.
Cheers.
-shim
Thanks.
Cheers.
-shim
