Problem installing downloaded models in reflex
Hi Guys,
I don't seem to be having much luck installing downloaded models into Reflex sim. I keep getting error messages indicating that there was a problem reading the image file or that the mod file was not available despite it being in a folder in the aircraft section of the program files/reflex section of my c drive.
Anyone able to help?
Craig.
Craig.
Craig,
Ive found many of the downloaded models do not work. Others work but are very poorly written.
There are a few good ones though.
The ones Ive downloaded come as zip files, so you must first unzip the files. Then place the unzipped folder into you plane folder.
Are they zip files and have you unzipped them.
kiddo,
Heres the site
http://www.reflex-sim.de/reflex-sim/...3578e8b3c6ed8b
Caution. The Reflex models will be good. Some of the Friends models are good to. But many are rubbish. Will not load. Are twichy, or completely unrealistic.
Problem is now theyre all mixed up with the good models so its difficult to dlete them without deleting the good files.
Cheers
Heres the site
Cheers
Heres another source for good models;
http://www.rc-sim.de/index_en.htm
and if you want a class model for around 3 bucks:
http://www.w3g.us/Default.aspx
(and once you get there you will find a few more links to other downloadable sites for REFLEX models..
Hope this helps!!
John.
Hope this helps!!
John.
