RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Anyone have this.
Old 11-07-2006 | 11:46 PM
Kevinator9's Avatar
Default Anyone have this.
Does anyone have Tru-Flite 3D or know anything about it? please someone answer. I have put lots of posts in this particular forum and have had almost no replies on anything I say...
Old 11-08-2006 | 12:29 AM
Default RE: Anyone have this.
ORIGINAL: Kevinator9
I don't have the program, but I do have a suggestion. You probably aren't getting the responses you'd like because of how you've written your topic. "Anyone have this." doesn't tell anyone what the topic is about. A better title would be, "Does anyone have Tru-Flite 3D?" That would at least give people who have it a reason to click on the topic. Also, you might want to spell out just what you're looking for in the body of the message. Asking if anyone has or knows anything about the program won't likely lead to whatever piece of information you're looking for.
Old 11-08-2006 | 12:33 AM
Kevinator9's Avatar
Thought it may be better to ask first but here is what I need. Can someone give me these specs for a caliber 5 or 3?
Blade Cord: 20mm - 100mm
Rotor Diameter: 1200mm - 1850mm
Pitch at Max C/L: 10.0deg - 18.0deg
Max C/L: 0.5cl - 2.5cl
Pitch Curve
Collective Pitch Travel
Top: 0deg - 16deg
Centre: -10deg - 10deg
Bottom: -16deg - 0deg
Cyclic Pitch Travel
Roll +/-: 3deg - 10deg
Pitch +/-: 3deg - 10deg
Control Rotor
Paddle
Weight: 1g - 75g
Area: 5sqr/cm - 100sqr/cm
Fly Bar
Diameter: 250mm - 800mm
Tail Rotor
Blades
Rotor Diameter: 200mm - 400mm
Cord: 20mm - 60mm
Control
Pitch at Servo Centre: 1.0deg - 10.0deg
Total Pitch Movement: 5.0deg - 30.0deg
Gyro
Gain
Gain A: 0% - 100%
Gain B: 0% - 100%
Response Time
Speed: 100ms - 500ms
Static: Single Rate/Dual Rate/Proportional/Heading Lock
Air Frame
Parastic Drag
Cd: 0.01cd - 0.40cd
Dimensions
Total Weight: 1.50kg - 10.00kg
Weather Vane: 1.0 - 10.0
Tail Rotor to Mast: 300mm - 1500mm
Transmission
Gear Box Ratios
Engine/Main Rotor: 7.0:1 - 20.0:1
Engine/Tail Rotor: 2.0:1 - 8.0:1
Clutch
Engage RPM: 2500rpm - 8000rpm
Main Rotor Rotation: Clockwise/ Anti Clockwise
Engine
Maximum Power: 0.50bhp - 4.00bhp
Maximum RPM: 6000rpm - 35000rpm
