Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 One CPU or dual core for simulator? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 11-14-2006 | 08:51 AM
Scoubidou's Avatar
My Feedback: (17)
Default One CPU or dual core for simulator?
I have to upgrade my old computer and would like to run AFPD or G3.5. I am not a gamer so, the flight simulator would be the biggest programm in my computer.
Is there a real difference other than cost between a AMD 64 bits 3500 or dual core AMD 3800 CPU, if i do not run many programs at the same time?
Daniel
Old 11-14-2006 | 08:59 AM
Default RE: One CPU or dual core for simulator?
Keep in mind that Windows has a ton of programs in the background all the time. Some may run whenever they decide without your ever knowing. Heck, some may be running right now, as we speak....... scary isn't it......
Old 11-14-2006 | 11:26 AM
Dual core CPU's are so much better, once you have one you never look back.
Stefan
http://rcflightsim.com
Old 11-14-2006 | 12:56 PM
Scoubidou's Avatar
My Feedback: (17)
i'll go with dual core Athlon 64, 3800
Old 11-14-2006 | 04:42 PM
Raylon's Avatar
That's what I have, and love it. Do note that you MAY have to set the affinity on some games. Older games tend to freak out when they see the dual cores. Not sure why.
Old 11-14-2006 | 08:21 PM
ORIGINAL: Scoubidou
Daniel
Bit more technical if you want,
There are 2 or 3 reasons whay the 3800 is better than the 3500.
First as you have not stated it explicitly and as I can not be bothered to check, the dual core CPU is not marked as 64 bit, now 64 bit, will have larger capacity for floating point numbers and the such and should run faster as a result, can do more with a single operation, however most modern computers are still running 32 bit operating systems, and lets face it why would you be running windows XP 64 on a processor that is not 64 bit (not even sure it would work) so in that respect there is not difference between the 2.
Second, the clock speed, which for AMD's has to be taken with a pinch of salt, the 3500 and 3800 are intel range speeds, so for instance the 3500 will run at the same speed as an intel 3.5GHz processor, for the most part these can be trusted and are useful for comparison. If you want to know more as to why PM and I will explain but I don't think this is the place to get into it. So the higher the number the faster the processor will go the more operations it will do.
Third a dual core CPU is 2 CPU's in one chip, kinda like buy one get one free. So the computer is able to run 2 programs turely concurrently not like single processor where it has to swap all the time. Importantly here if a program has 2 or more threads, which most programs do these days then they will run alot faster. It is likely given the very new nature of the simulators that they are indeed multithreaded.
So in summary
1) no difference
2) 3800 1 3500 0
3) 3800 2 2500 0
result 3800 winner.
HTH
J
Old 11-14-2006 | 08:29 PM
I would definitely go with the dual core. It will be especially beneficial for the physics and graphics engines that are running simultaneously in the simulators. I have an intel dual core processor and it it one of the best things I have ever purchased.
Nathan
