RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
FSOne Q's
Old 12-29-2006 | 04:50 PM
Default FSOne Q's
Folks,
I have been playing with FSOne and love the flying aspect of it (not so much the installing and loading part).
I have a few questions:
- Is there a quick way to change the remote settings, like mixers and such? Exiting the simulation and changeing them in the main menu and then restarting the simulation takes several minutes of loading and makes this part a MAJOR frustration.
- I am practising a lot with the twin coaxial electric copter as I have one of those as a real model.. My problem is that the one in the simulation isnt stable in that regards that it will always circle as if it was a pendulum on string... hard to explain ... Is there a way to fix this? The trims on the remote dont work for that..
cheers
Matt
Old 12-29-2006 | 11:23 PM
Default RE: FSOne Q's
ORIGINAL: FearNot
Folks,
cheers
Matt
Contact Hangar9 support via telephone -- they can talk you through how to tweak the Blade CX to reduce the "pendulum" effect and may also be able to answer other questions you may have.
Old 01-03-2007 | 07:44 PM
Has anyone figured out how to use the transmitter that comes with the e-flite Blade cp with the FS One simulator? What cable is used to connect it. It looks like a standard s-video cable, but i tried it and it did not work.
