Twinstar problem
I cna land everything else fine, piece of cake. I cannot land the twinstar for the life of me. I've even switched to in cockpit view, and landed it with the TRIM, and it will still crash.
What gives?
Are there any other twins out there that I can DL?
I don't have any add-ons.
What gives?
I'm trying different approach speeds, but still the same thing. It touches down, then crashes. I've landed it twice with the elevator TRIM control, I mean GREASED it in, and it still wrecks..
Perhaps my dreams of building a P38 are fadeing away...
That fixed it. Wow, twinstars with 23lb turbine engines in them are fast.
On a serious note, the turbine models SOUND so good. It's too bad you need to bring 5,000$ to the plate to even think about entering that side of RC. Maybe in the future, the prices will come down a bit.
TN
Thanks Trumpy,
I couldn't land that puppy either without crashing. The "keep the speed up and grease it in" worked for me once or twice, but ghee whiz, nothing should be that hard to land! I assumed it was me cauz surel GP wouldn't get it wrong (wrong!).
Joel
Joel
well if u want to.............................. there is a cheat to fix the landing crash on one of the G2 unofficial swap sites. I saw it under the new Beachcraft Bonanza scheme.
Me i like to do it the hard way, Maybe the real thing is like that and u might have to tweak the gear on it too.
i have same problem.. i find if you get it at stalling point at 10-12 foot with elevator right back and just apply throttle.. but thats me!
hey!
do you have any add ons for great planes realflight g2 because we could all share software eg.. aeroplanes hellis etc if we all logged on to
WWW.KAZAA.COM
*download the satelite and your off!y!
hey!
WWW.KAZAA.COM
Go to Miscellaneous and adjust landing's easier than changing aircraft unless you want to change it . You can adjust where it lands every time unless you stick in the ground.
My Feedback: (13)
IA
OK, great..which one do you adjust on the landing gear?....I adjusted one of them and went back to fly it and the plane keeps bouncing all over the place...won't fly..did i hit the wrong button or what?.....another thing. I can't get there website..keeps telling me about a firewall or settings, and an error...problems,problems, problems....any help there??
i got it lads.
Go to Aircraft/Edit Twinstar/Fuselage/
Landing Gear/Main Gear Location Forward = -1.6
Up = -6.8
And then Have Happy Landings!!!!
Up = -6.8
