Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
G2 controller and USB adapter question >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 03-14-2003 | 04:40 AM
Campy's Avatar
Default G2 controller and USB adapter question
I have seen several references about using the game port type G2 controller in a USB port. The only things I have been able to determine are: 1. A Radio Shack game port to USB adapter is needed. 2. You need to specify a "joy stick" to use.
IF the right position is selected on the adapter (there are 4 positions) AND the correct "joy stick" is selected the game port type G2 controller will work when plugged into a USB port.
Can anyone provide the correct switch position on the adapter AND which "joy stick" to select ? I have experimented with a variety of switch positions and "joy stick" settings, but have had no luck in getting the RealFlight game port controller to work properly.
I would like to do it with the adapter rather than spend $$$$ for a new controller.
