RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
lap top and g2
Old 10-26-2007 | 06:10 PM
Default lap top and g2
i cant install g2 on my lap top which has windows vista is there a patch
Old 10-29-2007 | 08:45 PM
Default RE: lap top and g2
It will work fine. Do not install with the autoloader. Cancel that. Then go to the cd and install using the setup run as administrator and in xp compatality mode. To set this, right click on the setup icon. There is a compatability tab, click to run the program under windows xp mode. You will need to setup the G2 icon to run the same way. Works great. I could not get it to work normally. I installed twice till I figured out how to get it to work. If you have problem PM me.
Rod
