RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
KE ERROR!
Old 12-24-2007 | 12:39 PM
My Feedback: (12)
Default KE ERROR!
After months of use on my off-line dektop all of a sudden my RealFlight isgiving me an error that halts the loading of G3. THe error looks like this
NEERROR 95020 CriticalFileWriteError.
I figure it must be one the planes I downloaded from Knife Edge.?
Do I need to remove the entire G3 program and re-load it. THen selectively ADD back the KE planes.???
I'm thinking that the 95020 identifies one of the planes I loaded but can't tell cause the program will notfully load!.
Merry Christmas......hope Santa treats you well!>>>Mikel-T
Old 12-25-2007 | 12:10 AM
broke_n_bummin's Avatar
Default RE: KE ERROR!
Unless it was the last plane you loaded, or it was the one that was loaded when you shut the program down, I wouldn't think it would be a plane you downloaded. If you know which one it was, you can remove it manually by deleting the files from the folder. The program only loads the plane and scenery it was using when it shut down last. If that doesn't work, you might try a system restore. I don't believe G3 can be loaded in safe mode, but you can try that too.
Old 12-25-2007 | 01:21 AM
Bad_Daddy's Avatar
Is the drive full?
Old 12-26-2007 | 12:41 PM
My Feedback: (12)
Did the system Restore...no luck. Had to delete the entire G3 and reload it again and Add-ons. Seems to working fine!. Now just have to find the plane I downloaded from KE that may have corrupt the files. Hmmmm.
